Clutch Pedal Clip
jmd
Clutch Pedal Clip
Has any viewer any advice on fitting a Clutch Pedal Clip(Which holds the cable)on an Xantia 1.9TD (96 Model)
marco1
its a bugger..long nose plyers really long or no chance.ive done it,pedle has to come out cut off bolt head if its in the factory fit wronge way!!put new clip on new bolt other way push cable up in to car have someone hold it in while youlift pedle up so that clip engages end of cable you will hear a nice clik when its in, job done then adjust cable per car instuctions have fun!!!!
