Hi I am a new member and have just purchased a 1992 XM ex French Embassy car in Canberra My problem is the Aircon/Heater controls when starting the car there is a clicking coming from the control panel I turn the temp control and it stops It sounds as if a gear is slipping any suggestions on this problem
Many Thanks [?]
Aircon Heater controls XM
aengus
heater flap servo hitting the end-stops perhaps? could be worn brushes in the servo motor.
it's located on the LHS of the heater assembly up above the footwell vent. Access is a pain, but if you can get a hand up to it, you can feel a lever that will move to/fro as you change the temperature settings. When you first power up the car, the control panel will wiggle the motor a little to get position feedback from the servo, you may hear a little whirring for a moment when it does this.
I had one that kept getting stuck at one end (hot, unfortunately) or would just not respond at all.
It's held in by 2 philips screws, but not much access. need to remove the dash lower trim panel and maybe the tunnel carpet panel too. You may be able to overhaul it if it's this that's the problem.
regards
regards
- x 1238
MICHAEL LIPSCOMBE
