Xsara HDi, V reg. Exclusive model:
The floor area, and plastic covering to handbreak, gear stick etc is always very cold in winter. Heating works fine but floor area is always too cold. Wife complains and has to wear thick socks etc. It's always been like this from new.
Is this generic problem with Xsara - or could there be a missing grommet or whatever in floor pan or bulkhead?
Minor prob I know, but can anyone help?
Xsara, floor is cold in winter
Clogzz
- x 40
shos1053
Clogzz
- x 40
johnway
Interesting this one as I have the same problem with my '97 Xantia. Slde control works as it should but I never get hot air at the footwells, plenty at the top. With the air con on, nice cold air does freeze the totsies, though!! I have heard other Xantia owners with the same problem but I am not going to rip the dash out to investigate (maybe some real keen type will do so). Must be a stuck valve of some sort, methinks. John.
Clogzz
- x 40
From what I gather on the French 'Planète Citroën' site, besides the slider controls there are also stepper motors that operate flaps to vary the air flow.
If you set all the air to flow to the footwells, at start-up on cold mornings you still get hot air in the face first, then, progressively, the hot air is directed to the footwells.
This system is like idle stepper motors and is prone to sticking valves.
I'll explore a bit and post any findings worth sharing.
