My 1994 xantia 1.9 td went for an MOT last week. Previsouly i did tinker with the the idle speed/fast idle and the idle speed was close to 900 rpm (becz of the cold start device is not working). Car failed in the MOT diesel smoke test. It was close to 1.0 last year. this time it is over 5.0 (cut off being 3.5 for turbo i am told). After much discussion our friendly tester/assistant did something to the pump (they turned something 'down' they said) and then the emission is now below 0.4 and I got the MOT.
Although i am very happy with the MOT result
, this car is suddenly acting like a tired cow pulling a cart. At roundabouts i have to floor the accelerator and still it will move like an ant. Two days ago engine suddenly switched off at roundabouts - not always but happens at least once in my trip.
I also noticed that when i pull the accelerator cable with finger at the pump lever end - nothing happens for a while and then only engine revs up.
Since i am scared of the car stalling at roundabouts, i keep an eye on the rpm counter and noticed that sometimes the rpm counter is going well below 400 when i take my feet off the accelerator to change gear - may be this is what resulted in the dangerous stalling at roundabouts ?
Any suggestion/advice on this will be highly appreciated.
(Can this be sorted out by adjusting the clip on accelerator cable - near pump lever so that there is no slack in responding to accelerator pedal ?)
Roy - 1994 Xantia 1.9TD
