xantia activa clutch
jackherer
Unread post by jackherer »
hi,
I've bought an activa as a temporary replacement for my xantia v6 while some work is done on it and there are a couple of issues I would like to sort out. The first is the clutch, the biting point is very high, and I gather the pedal is connected via an hydraulic linkage that is sealed and non adjustable. So does this mean the clutch is very worn? It doesnt slip even when provoked so I'm not keen on changing it but I might if this is the only solution.
cheers,
Kieran
jackherer
no one got any knowledge of hydraulic xantia clutches?
x 1237
Unread post by Peter.N. »
If its hydraulic it should be self adjusting, if it doesn't slip and has some free movement I would guess that its supposed to be like that.
x 1432
The normal 2.0 uses the same pull clutch as the TD. It's quite possible the Activa uses the same one as well. Biting point at the top of the pedal indicates it's on its last legs, but if you can't make it slip, and it's not really heavy (which can lead to breaking the plastic clip on the pedal, replacement of which is 'interesting') I'd just live with it.
Homer
x 16
Unread post by Homer »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by RichardW</i>
Nope, the Activa (2.0 Turbo CT engine) uses the hydraulic clutch as found on the HDi and V6.
The question is, is it slipping? If not I wouldn't worry, they do feel as if they bite rather high.
DoubleChevron
Unread post by DoubleChevron »
C'mon guys,
there's definatly going to be an adjuster there somewhere... I've seen an old Mini with a hydraulic clutch, and there is a 'resting' pin to prevent the slave cylinder withdrawing to far (requiring you to push the pedal to far).
seeya,
Shane L.
Mandrake
x 694
Unread post by Mandrake »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Homer</i>
What ?
There's a manual version of the V6 ? Or was that a slip of the fingers [:D]
Regards,
Simon
Homer
x 16
Errrmmmmmmm.........
Wishful thinking on my part. I think the Pug manual V6s use the same setup though.
bencowell
Unread post by bencowell »
Wasn't the Activa available in V6 manual abroad?
handyman
Unread post by handyman »
Yes but not RHD, I have tried to source one, without success!
