Xantia Steering Hidraulic HISSSSS
rodrigoareal
Unread post by rodrigoareal »
What's that hisssss that goes on when I'm turning the steering wheel either way ?
Is it normal on Xantias? Or could be a problem on the hidraulic system ?
Rod.
Fox
Unread post by Fox »
Mine does this as well. I'd assumed it was normal.
1994 Citroen Xantia SX 1.9 Turbo Diesel
147,500 miles
dirtydog
Unread post by dirtydog »
I have the same Hissss but Citroen say it is normal on Xantias, althought I cant remeber it doing it on my BX.
Regards
DD
akojic
Unread post by akojic »
I think it is normal thing!
Cheers<img src="" border=0><img src=icon_smile.gif border=0 align=middle>
IanR
Unread post by IanR »
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote>I think it is normal thing!<hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote>
It is indeed. Especially when ssssnaking around parked cars in our street.
shaunthesheep
Unread post by shaunthesheep »
i think you will find that it is the norm, as when i first brought my xantia, i asked about the hissing from the steering area, & was told "thats the sound the hydralic power steering makes when the car is at low revs". so i think that you will find that it's not a problem to worry about.
dom
akojic
Thanks Dom
wonderd
Unread post by wonderd »
I don't think it's normal - i drove a couple of them myself and there was no hisssss from no where, my bx is doing the same thing now and it didn't use to
Elad.
ACTIVE8
x 6
Unread post by ACTIVE8 »
Yes it's perfectly normal for the Xantia to do this.
Other makes of cars can be different to this, and not make a noise until they are on full lock, and held there.
I knew this mate who was troubled by this, and thought his car had a problem. I had to let him know that it had to do this as it needed to have a pressure relief while on full lock, and as the P.S. fluid flow was being redirected by the pressure relief valve, the noise was a consequence of this.
The Xantia makes the noise because of it's design all of the time, and is more noticable when you manoeuvre at slow speeds.
dan.2cv
Unread post by dan.2cv »
Yep, all quite normal, every hydraulic Citroën I've had has done it. Quite normal on LDV vans too, just 100 times louder just to make the worst driving experience possible even worse!!
np
Unread post by np »
Mine does it.Although like Active8 says,i can only hear it when parking.
ACTIVE8
x 6
Yes I tend to notice it when parking on my Xantia, but that's probably because the amount of other noise from the car is less.
By that I mean there is less engine noise, no road noise, the stereo is turned down, or off. So while you are parking it is more obvious.
With other makes of vehicles, I have noticed that the steering column tube can actually transmit the noise away from the source, direct it at the driver, and actually make it sound louder than it actually is, by amplifying the noise, and the problem.
