xantia mark2 plip
meexi
xantia mark2 plip
Unread post by meexi »
Here`s a poser for you my plip on my xantia will not unlock/lock the doors but will still start the car so that would rule out the plip battery or would a flat plip battery still enable me to start the car?
cheers
bernie
Unread post by bernie »
I may be wrong but I think the batteries are only for remote c/l and alarm setting whereas the key has some form of chip that is recognised by the ecu for allowing starting.
rossnunn
Unread post by rossnunn »
yeh the key uses a transponder code (I know all about these!! lol), as bernie says its probably a flat set of batterys. Can't remember if the mk2 key still has a red led on it?? If it does ckeck to see if that is coming on when the button is pressed.
You'll need CR2025 batterys for the remote.
