2000 xantia stereo removal
easterroad
Unread post by easterroad »
Hello,
Does anyone know the procedure on how to remove the stereo from a late 2000X xantia?
The stereo is a factory fitted RDS cassette job kept under a flap.It has 4 little holes one in each corner, are these used in the removal or is a specialised key needed?
Thanks!
Rostami
Unread post by Rostami »
normally you would need two thin round wires. I usually use two thin screwdrivers (2mm diameter). push the scredrivers on the holes on the left. you will feel a spring being pushed away in each hole. then you can pull the left side of the radio out (about 1cm). The same with the right side. and Voilá!
easterroad
brilliant, thankyou!
will give it a go tonight
