HAS ANYONE GOT THE ANSWER!!
I HAVE A 'N' REG 1.9 D 406 WHICH HAS A REALLY ANOYING DASHBOARD CLOCKS PROBLEM. AFTER RUNNING FOR APROX 6 MILES THE REV COUNTER TWITCHES THEN STOPS AT 2000 REVS, THE MPH CLOCK TWITCHES MOVES IRATICALLY FROM ONE SIDE TO THE OTHER THEN STOPS.THE DERV GAUGE THEN GOES TO EMPTY.OIL TEMP GAUGE REMAINS OK. DOES NOT DO THIS AT COLD.
TRIED ANOTHER SET OF CLOCKS AND ALSO HAD AN AUTOMOTIVE ELECTRICIAN CHECK WIRING AT BACK OF DASH CLUSTER.
PLEASE CAN SOMEONE HELP BEFORE I GO CRAZY !!
