Grr Xantia Brake Lights
mattpc
Unread post by mattpc »
Drivers side brake light is out on my T plate Xantia HDI hatch. On the PASSENGER side there is a wing nut to undo with enough space to turn the nut. On the DRIVERS side which is the side I need to do there does not even appear to be enough space to turn the wingnut! So how do I withdraw the assembly without undoing the wingnut? I am puzzled!![xx(]
wrinklet1
Unread post by wrinklet1 »
You cant. You need to undo the wingnut.
Sorry.....
wrinklet1
Sorry.....
mattpc
Ah, Did it. Forced it to move using a screwdriver and then eventually the carpet moved enough to allow the wingnut to just about move properly!
splat
Unread post by splat »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by mattpc</i>
You made the mistake of thinking about it before hitting it. That rarely works.
mattpc
