ZX engine replacement XUD9TE
UserError
Unread post by UserError »
Hello,
I'm considering replacing a ZX DT engine (D8A)-head gasket gone again. Are other marque XUD9TEs also suitable, eg Pug 306 BE3-5 unit? Is it the ancilliaries & mountings that make the difference or do the block/heads etc differ?
Thanks for any advice.
Jono
x 1238
Unread post by Peter.N. »
I think that all the XUD engines are basically the same, providing they are of the same year/type, but the anciliaries are different for each application.
rossd
Unread post by rossd »
BE3-5 is a gearbox type not an engine! The older 306's also used the D8A engine. [:)]
UserError
Thanks for confirming what I thought.
RossD, thanks for putting me straight on the gearbox issue -
I'm not at all familiar with Pugs so took the info from the Andyspares data sheets. Just revisted them & the field for Peugeot is Engine/Gearbox, while the Citroen is engine only.
Ta
Jono
