BX LHM
Rob Marshall
BX LHM
While I'm posting like mad....
Changed the LHM on my car last summer, and then did 2,000 miles on hydroflush; filled up with new LHM and bled it.
Checked the condition of it a year and 10K later...and it's going yellow!! Amm planning to change it next year, but surprised it's going yellow already!
oilyspanner
martyhopkirk
Rob Marshall
ScottFromNZ
My BX's LHM was changed about 2 years and 13,000 miles ago. I had a look in the reservoir yesterday and it is brown. So this mornings job was to clean out reservoir and put in new LHM. I will monitor the colour of it more often now and change it more often I think.
I don't know how often it was changed for the first 12 years of the car's life before I owned it.
czenda
Rostami
- x 94
- x 1238
cauchoiskev
Rostami
Sir Clive
I always used to do a yearly LHM change on both the BX and the Xantia. It seemed like a good idea, and I never had any hydraulic related problems. After a year the fluid always had a slight yellow tinge, which is OK, but when it starts to go brown it definitely is time for a change[:)]
Regards
Philip
Regards
Philip
adamskibx
I changed my LHM with the proper stuff in green and white tins, and even bled it out through brakes to get every last bit of hydraflush out but noticed black bits moving within the fluid when attending to a disconected clear return pipe coming from the rear struts- ie, I put the car from max to min and quickly got out to have a look at where fluid was leaking from and saw the black bits move as fluid came out. Hopefully as its just a trickle return it will either never get back to the tank or will be filtered out if it gets there.
- x 94
czenda
