help I need to flush my raidtor
Icey
how do I drain my raditor on my Citroen exsara I cant find the drain nut
wrinklet1
j_roc
For best results you should remove it from the car to flush it. Let the water flow through it for about 5 mins, then put the hosepipe (with a good bit of water pressure) in the other pipes in the rad as far as you can get it and reverse flush it. Don't forget to turn the radiator at different angles with water flowing through it to dislodge silt/sludge/rust because if you dont do it thoroughly, when the rad gets blocked at a later date by ch**st will you know it. Also dont forget to flush the rad pipes, block and matrix. Hope this helps - Alex.
oilyspanner
