car just wont start
christine mellor
car just wont start
im at my wits end with my x reg xsara some days it runs like a dream other times it just will not start ive had it in the garage numerous times but they have done minor changes but cant find the cause any ideas[:(!]
DLM
Christine: the first thing required to start to give any is a little bit more information. Is it a diesel or a petrol-engine Xsara, and what model is it? Is there a pattern to the starting failures (e.g. good/bad weather, after long/short runs, hot/cold engine etc.)? What have you been told by the garage about the problem? For how long has it been going on?
Please don't mention the garage name as this forum's aim is to provide technical help if possible on the terms outlined by the moderators, and not to give cause for any litigation.
christine mellor
dnsey
- x 19
stubbsy
- x 94
- x 1238
More thane likely as Stubbsy says, an intermittent stop solonoid. If you look at the fuel injection pump you will find it in the top at the end nearest the middle of the engine, it has a single wire connected to it. To check it, you can remove it and take out the plunger and spring from inside, refit it and it should start every time, only you will have to put it in 5th gear and stall it to stop it.
Kowalski
- x 1238
christine mellor
