Citroen Technical Training Hydractive II manual
Update:25 Sep 05
Hydractive II PDF link now available for view or download
Hi all,
Citroen Technical Training Hydractive II manual link now available!!
As some may already know, Richard Gallagher and myself have been working on making "Citroen Technical Training - Consultant Technician Module B7 Hydractive I and II systems for XM and Xantia” available on the web. These manuals are from Citroen’s own in-house training for dealers, which I think worth publishing as it contains diagrams and lots of technical data for Hydractive that may not otherwise be available!
After many weeks copying, scanning and web building we’ve managed to get Hydractive I and II available, with Hydractive 3 and 3+ coming soon. Later we hope to get Activa and BX hydraulics up too!
It consist of photocopied pages in an album format. Each page range can be downloaded in a higher resolution JPG to allow zoom on complex diagrams etc: using Windows Image Viewer, for example or viewed in PDF for Adobe readers.
Pages not deemed useful have been excluded to cut down on site size. Generally speaking, 95% of the original manual(s) are included.
Personally, I’ve been hoping to offer something back to this excellent forum for some time as it’s really helped me out in the past. Hopefully this site can grow and become a real resource that may benefit many of us Citroen owners looking for published technical data and the alike. So if you’ve something to share email me at [email protected]
I’d like to thank vanny for his expertise in producing the quality PDFs for the site and for the time he spent converting my scanned images. Thanks vanny !! [;)][:D][:D]
The site has been kindly donated by SMJB Web design ``for all your web design needs!’’ So if you like the site and want one yourself for business or pleasure, email: [email protected] for a quote. Plug over !!
Click http://www.stevenbraud.demon.co.uk to access Citroen Technical Training - Consultant Technician Module B7 Hydractive I and II systems for XM and Xantia manual.
Cheers
Steve
Mandrake
- x 694
Thanks Steve,
This is wonderful. [:D] I'll be printing a copy out today.
You mention that some pages have been left out, can you comment on what kinds of things they contained ? Is there anything about whether the damper valves can be removed and replaced in the hydractive control blocks ?
Regards,
Simon
Regards,
Simon
bernie
Mandrake
- x 694
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by bernie</i>
Yes, Simon they do come out after removing the large (27mm I think) spigot that the HA pipes connect to.
So they're only held in by the spigot and not an interference fit in the hole like the ones in a sphere neck ?
Regards,
Simon
Regards,
Simon
sbraud
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Mandrake</i>
Hi Mandrake,
As far as I'm aware the only parts left out are of the `acknowledgements’ and non technical variety. Richard G made the copies I used for site and would be best placed to answer this point. That said I’m sure when we discussed the manuals he said most of their content was available. Only a few pages that were of no value were dropped.
Cheers
Steve
Hi Mandrake,
Cheers
Steve
bernie
Regards,
Simon
Yes that's right Simon, the 2 HA2 blocks (mine 1999 and a spare 1996) have been the same.
Undo the 30mm nut (NOT 27mm as I said before) and there it is.
One more point the spigots are different I have because Citroen changed the pipes between block and cylinder on later models. Different angle crimped ends.
Regards,
Simon
Mandrake
- x 694
Great, I think I might pull them out and have a look at them to confirm they're not "faulty" before trying a sphere with a valve for extra damping. I guess the only thing that could go wrong with them would be if the washers cracked or lost their stressing.
Is there some kind of identity which way around they go back in or are the damper rates for in and out the same ? Do you think I might be able to get them out in situ on the rear control block (just take the feed pipes to the cylinders out, and the spigots, and leave the main block in place) or would I need to take the entire block out to be able to get enough access to get the valves out and in again ?
Regards,
Simon
Regards,
Simon
bernie
I removed the whole block to strip mine but after removing the pipes and spigots in situ, yes the valves fall out.
On mine the side with the number faced the pipes.
I've checked mine by sight but there does not seem to be much that can go wrong.
Note. I've only stripped the rears so far so I know you can get to them
sbraud
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by sbraud</i>
Update:25 Sep 05
Hi all,
Cheers
Steve
Update:25 Sep 05
Hi all,
Cheers
Steve
sbraud
Dear all,
My sincere apologies for loss if site.
I moved house back in May and had to move ISP and so webserver went offline. New house has kept me busy since then but like all good intensions… I’ve been meaning to sort it out since Aug !!
Gateway and server are live and I’ll sort it out for New Year.
If in the meantime you need anything from site please email me and I’ll endeavour to email manuals back to you.
Cheers
Steve
Cheers
Steve
95 Xantia 20/16v 155 bhp VSX 210k
97 Saxo 1.1 SX 100k
03 S-Type Jag (sorry!)
``Only standing on the shoulders of giants - The more I know, the less I understand?? Ignorance is bliss! ''
97 Saxo 1.1 SX 100k
Caterpillar
Re: Citroen Technical Training Hydractive II manual
Hello sbraud, in search of detailed informations, the winding paths of the internet led me to your post. I can see how old it is but I believe you might read my message. It concerns the Citroen Technical Training Hydractive II manual, which unfortunately cannot be found. You mentioned that you would send it by e-mail. The problem is that I can't find your address to write directly. I hope you read this message.
Best wishes
Best wishes
- x 5582
sbraud hasn't been on here since 2017.
You may be able to contact him by private messaging though.
Click the "Contact" bubble and choose the PM button - or email if it is active - to send him a message.
- x 1750
The document is still available on-line.
Google "Citroen Technician Training module B7 Hydractive".
The pdf can be downloaded from the www.scribd.com site.
