xantia td not the usual speedo problem!help
backline
Unread post by backline »
on removing the electronic sender unit to investigate a non working speedo i noticed the worm gear at the bottom of the sensor was missing,on having a poke around it seems to have broken and become lodged/mangled inside the housing.
would appreciate any help on removing it without having to take off the drive shaft,or advice on partialy removing the offside drive shaft to gain access if possible.anyone came across this one before?
