Hey lads, my car dropped all its box oil, apparently the place where the speedo connects to the box is cracked? Any idea where / how much they go for?
Cheers
Kev
306 XSi Speedo connector
bad driver
I had a similar problem, speedometer drive housing broke which is the bit you are describing. The part seperate from pug is around £60 plus VAT if they are willing to order it for you. Most scrappies wont split them from the box either, I suggest trying to find a breakers where you remove the parts yourself and trying to remove it then pay for something else.
Linchpin
