Radio Lighting in Xantia TD
sonvue
Is there a lighting system so you can see the radio controls in the dark? How do you repair it as Haynes does not seem to mention it?
handman
i think it will be the same as the petrol models - remove the ash tray look in the upper area of the ash tray you will see 2 torx screws remove them and the outer facia of the radio and heating system will come off you should see all the other torx screws behind that to remove the radio, are your heater lights comming on if not there could be a blown fuse i would check that first it might save a lot of time. hope this help
shaunthesheep
