My 89 405 gr doesnt have rear electric windows and i was just wondering if i could get the switches and the motor would i be able to have rear electric windows ?
thanks
rear electrics windows (405)
- My Cars: Current - Slightly modified 2016 Pug 308 Puretech 130 Allure
Past:
2003 - 206 GLX TU3JP & 206 SE ET3JP4
1995 - 405 Executive XU10J2
1996 - 406 GLX XU10J4R
1994 - 405 GTX XU10J2 - x 1
Hi
You also need all the wiring that goes with them as well as the hassle of fitting them.
Peugeot used a lot of different looms on the 405, You would need to find a GTX/ GTDT or MI16 of similar vintage & borrow the parts of the loom you need of that.
The 405 never got the standard one loom fits all untill August 1994.
It IS possible to do this job, But for all the time, effort & money it will cost to do its not worth it.
Past:
Hi
To do this job you would need the 2 x door motor regulator assembles & the 2 door wiring looms that go with them.
Also needed would be the 4 switches & the child safety switch & the loom that goes with that lot, Also I think the centre consul trim panels would need to be changed, I think thats just a couple of clips though.
Have a look in the centre consul where the switches would be for 4 brown connector plugs with 5 wires in each floating about doing nothing, You MIGHT be lucky, If you do find them you might be on to a winner!
Then you need to see if the loom between the consul & the 2 rear doors is the same, If not you would need to change that, Are there 2 spare thickish wires up to the rear door connector plug doing nothing?
Then you have to see if the loom from the fuse box to the centre consul to power the whole lot is the same too, Again you might have to change that.
Then theres the hassle of finding a pair of good door cards with the same trim on to replace the ones you have with the holes in.
Unless you can find a GTX / GTDT or MI16 to rob parts off its gonna be a struggle.
