diesel pump question?bx 1.9
ssray
how much diesel will my pump send back to the tank? i`m in the process of doing a diy veg conversion and need to know if i can run the return just back to the diesel tank, in wich case i can get away with one solinoid valve
- x 94
ssray
Kowalski
rotodiesel
Difficult to generalise, as it depends on fuel injection equipment, installation and engine operating regime, but the fuel volume returned can be in excess of 80% of the total flow at low engine fuel demand and high revs. Make sure you keep the back pressure on the return line to reasonable limits, and watch the lubricity of any brew you choose to burn. The engine won't mind too much as long as you keep the cetane rating high enough to prevent detonation, but the pump will suffer if you get it wrong.
rotodiesel.
rotodiesel.
oilyspanner
