Radiator Bleed Screw on BX TZD
Roscoe
Unread post by Roscoe »
I have a quick question on the rad bleed screw on a BX TZD - mine only turns 1/4 turn and doesn't appear to actually open at all - is this correct or is there a trick to opening it? I'm referring to the bleed screw on the top right hand of the rad as you face the car.
G4EIY
Unread post by G4EIY »
Hi Roscoe,
These tend to get stuck if not used for a while, you will probably have to use a pair if pliers or similar to un stick it.
tomsheppard
Unread post by tomsheppard »
Some are silly. If yours is one of these,Turn 90 degrees anti clockwise, pull up and turn 90 degrees clockwise to release.
Roscoe
Thanks Tom - I think mine is one of those - it's plastic and I don't want to force it. Will try the turn, lift and turn trick on it!
