a little tip flywheel locking
handman
Unread post by handman »
i have just completed a major sevrice on my Xantia 16v 96 model new timing belt-aug belt-f/discs+pads-oil+filter,air filter-plugs-anti roll bar drop links-ANTI FREEZE-winter is here and well worth the effort--- now the tip is the tool to lock the flywheel its costly £45.00 yes so i used a torx bit large one male type of course, just remove the flywheel dust cover (dont bother with that last bolt hidden behind the sphere) just pull the cover out a bit and slide the torx bit in- it works for undoing and tightning the crank pully bolt putting the t/belt belt on was a pig though, follow the book you should only put it on one way
