Does anyone on here run there Xantia 2.1 on veggie oil?
If so what mix/any mods needed.
I've done a search and had a look around the web but would like to hear from any one actually running theirs on vegetable oil
cheers
Kin
Xantia 2.1 on Veggie oil
NiSk
shezads
Is it a bosch Injector pump? If so will be fine.
Start with 70-30 mix (diesel/veg) - and work your way up.
In warm weather mine seems fine at 90 - 10 mix (veg / disel) - 100% will work, will idle roughly for first 5 mins.
If you can fit a heat exchanger then that would improve things and you should be able to run 100% oil.
In the winter anything over 50/50 will get you rough tickover / bad starting.
If its a Lucas - forget it - it will damage the pump - some can last with a 75% 25% disel / veg mix - but anything more and you'll get failure of the pump unless the oil is heated (by two tank conversion)
kinrsole
James.UK
ssray
howiedean
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by ssray</i>
i tried 95%veg in my bx yesterday, pulled over to soon and would not start had to resort to wd40 in filter housing, if you use too much veg pour a kettle of boiling water over your injection pump, warms it up and helps when we have a cold snap(summer?)
During the last fuel crisis I used cooking oil amongst other things in my ZX and I must admit that it did'nt really run very well on the stuff. I now use Bio-fuel which is basically filtered used cooking oil with additives.
I use 100% biofuel in my (not the same it has a bosch pump)ZX now and it runs fine, a bit of smoke and rough running for the first 10 seconds then it runs better than diesel. As the temerature reduces I'll start to add diesel.
I'm trying to sort out an inline heater and a diesel changover switch for 100% running over the winter.
I considered buying a 2.1 Xantia myself but decided on a 1.9td (running 75% biofuel) so that I can run it on the cheaper stuff as I think the 2.1 has the lucas or equivalent pump.
Has anyone else here used Bio-fuel and sorted out the cold start issues?
<b>I Forgot to mention make sure you change the fuel filter regularly after used veg oil as it will drag rubbish up from the tank and lines and can block your filter.</b>
Regards
Regards
James.UK
I tried sunflower veggie oil from the supermarket in my ZX about a year ago. (Bosch pump).. [^]
I used a mix of approx 50/50 Diesel and veg oil. The car performed better on it, the engine tone was deeper, tickover was smooth and very quiet, and it accelerated better at all speeds, [:D] the only disadvantage was the fact that it was slightly less economic, i.e. it returned 4-5 miles ish less per gallon..
sooty
mipster
ActivaV6uk
Wookey
- (Donor 2019)
- x 12
I ran my C15 (XUD7) on straight veg oil for a year or so, using 2 tanks and an inline heater. It worked fine. That was with a lucas pump. Lucas pumps are fine but you need to do things properly and not just chuck some veg oil in. Get a heater and a switchover solenoid and a second tank for the starting/finishing diesel. There are now loads of suppliers for the bits. Alternatively use one of the bio-diesel products. There are two. The well-known bio-diesel (made by transesterification of the veg oil in the presence of methanol), and the less-famous bio-power product 'MWVO' (modified waste vegetable oil) which I understand is simply filtered waste veg oil with some solvents/thinners added.
I haven't converted the new van yet as I haven't worked out what to do about the tanks. But fuel going up to GBP 1/litre obviously makes vegoil systems that much more cost-effective, even with the tax paid.
- x 1240
NiSk
Regarding TD12's from XM's - they have nearly all had the fuel preheater bypasssed - the aluminum casting was porous right from the start and they gave no end of trouble. You'd do just as well by winding a fuel hose round one of the radiator hoses a number of turns - as many as you can get on it - not that this is an any way as effective as the proper electrically powered preheaters, but as an alternative to the XM preheater . . .
//NiSk
//NiSk
