RGR Valve?
orion1210
RGR Valve?
Unread post by orion1210 »
Whats the RGR valve do on my 2.0 HDI?
Cheers
Homer
x 16
Unread post by Homer »
Is it an EGR valve?
martyhopkirk
Unread post by martyhopkirk »
Exhaust Gas Recircultion
Supposedly cuts down the amount of crap your car put out of the exhaust to harmonise us with Brussles - who wot be happy till we all drive round in milk floats.
fastandfurryous
x 4
Unfortunately, what they actually do is completely clog the intake manifold with gooey crap, and lead to a premature end to the engine. Disconnect it, remove it, blank it off and bin it.
The only positive effect they have is to (very slightly) reduce the levels of oxides of nitrogen in the exhaust. And even then, they only work at idle, or very light accelerator positions.
orion1210
Cheers guys,
So am i right in thinking it allows exhaust gasses into the inlet manifold or is it the other way round?
fastandfurryous
x 4
Your thinking is correct.[:D]
ralph
Unread post by ralph »
Fastandfurryous - where would you blank it off? Both ends or just exhaust end?
After having a flick through Haynes I'd guessed that some steel plate between the exhaust manifold and the EGR valve would do the job.
I can't imagine this would confuse an XUD (there's nothing to confuse) but would it cause problems for the ECU on an HDi?
fastandfurryous
x 4
I've done this on an ecu controlled XUD before, but not an HDI.
I took the EGR valve out completely, welded a small circular plate over the intake manifold port, and bolted a plate over the exhaust manifold port. I left the electro-valve connected, (this is the electronically controlled valve that controlls the vaccum to the EGR valve) but blanked off its vacuum supply, so the ecu still "sees" the resistance of the electrovalve, and still thinks it's connected.
Theoretically, you could just introduce a piece of steel plate between the EGR valve and the Exhaust manifold, but of you're going that far, you may as well just have the whole lot out.
In fact, thinking about it, you could just disconnect the vacuum pipe from the EGR valve, and blank off the pipe. This would mean that the EGR valve never opens (it needs an applied vacuum to open, it's normally closed).
Whatever you decide to do, deleting the EGR from a diesel engine can only be a good idea. The tiny emissions improvement it gives is utterly insignificant compared to the benefit of keeping that car on the road for a few more years, and thus not incurring the environmental burnden of manufacturing a new car.
x 1044
Unread post by wheeler »
best way it just to take the pipe off & shove a small ball bearing into the vac pipe.most HDi's also have a vaccum operated EGR throttle butterfly aswell to assist the EGR system,do the same thing to the pipe with that.
ralph
Thanks very much, gents. I'll get busy.
ralph
I blocked the vac pipe to disable the EGR valve.
The car used to regularly misfire slightly when accellerating hard in third gear.
I've driven it a few hundred miles and it hasn't missed a beat - a result!
