Which First?
jaguar306
Which First?
Unread post by jaguar306 »
I have a Xantia 2ltr HDI 90 on a V plate.
The rear suspension has gone very hard and I guess I should be changing the spheres? I imagine I should change all of them? Is it 2 front, 2 rear and one on the accumulator? so 5 in total.
Also need to hydraflush and change LHM fluid, should I do this after the sphere change or before?
Lastly will a normal oil filter chain wrench be good enough to undo and retighten the spheres.
thanks
mpr1956
Unread post by mpr1956 »
Hi, I'm not sure about the technical questions, but I can save you some skinned knuckles and five quid or so by confirming that a normal chain wrench will not be man enough to loosen the spheres ( It might work on the fronts if you're lucky, but it will surely snap like cotton on the rears !! ) ps. The spheres do not need a tool to tighten them on.. just as tight as you can do them by hand I think
x 1238
Unread post by Peter.N. »
Its unusual for the rear ones to go first, unless the fronts have allready been replaced, is the car riding at normal height? if not it could be a height corrector problem. If its Hydractive 2 it will have two wheel spheres and a centre one back and front.
Mandrake
x 694
Unread post by Mandrake »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Peter.N.</i>
Not that unusual.
In many markets the Xantia seems to be fitted with the "long life" multilayer diaphram spheres (3 dimples by the filler) for the front strut spheres - and they seem to outlast the back spheres because of it.
If they're just standard spheres on the front then yes, they'll probably go first...
Regards,
Simon
x 1238
You live and learn!
