Hi Guys,
Anyone in the Watford Herts area got a hefty chain-wrench or sphere removal tool they would be prepared to lend out for a couple of hours, a couple of cans of your preferred poison if there's anyone able to help..
Regards
Con L.
07910 081351
Xantia rear sphere change- tool needed..
Mosser
- x 94
ConLaw
ConLaw
mpr1956
The hammer and chisel approach does work... but you'll be under the car with the suspension on high and the rear wheels on the ground to hold the cylinders in place while you "crack" the sphere loose.. so you will in real danger under there while you're hammering away. Make sure that the car cannot sink on to you while you are working.. i.e. blocks or stands for all four corners...
ConLaw
Ok, Thanks for the advice, I think I will try the hammer & chisel approach; I will support the car properly, and I've marked the sphere to cylinder joint with tippex so as to see if its moving, once I've shifted it say 20mm would that be the time to lower it and depressurise the system, then spin the sphere off by hand? and have I missed anything there?
p20
ConLaw
