My C5 hdi speedo reads around 30% below the cars actual speed!
Whats the problem,speedo head,sensor,transducer??
Has anyone seen this problem,Citroen Australia appear confused.They want to replace everything and charge a fortune!
C5 speedo
jeremy
Kowalski
aengus
Mosser
The Seat Leon has a speedo that over reads by 9% on pretty much all of the range, but interestingly, if you bring up the diagnostics menu in the climate control system, you can access and view the actual speed of the car, it seems that Seat decided that the speedo needs to over read on the speedo, even though the ECU knows the exact speed the car is doing, i compared it to my sat nav system and the climate control speedo was within 1% of accurate, the speedo was always 8-9% out,
I think it has to do with the law which states that speedo's are allowed to over read by 10% but under read by 0%, so they add in some over reading to be within the law
406 V6
