Wheels off taken little clip off slid out pin with aid of punch, all going well. Now to remove the caliper with the T55 bit, it just wont go.
So i move on to try the disc retaining screws T30 bit, drivers side first, and again it just wont go. What the heck can i do? So i try soaking in WD40 all day and then i try with a small handheld propane gas thingy. Still no joy, bad news i have now part rounded the disc retaining screws on the drivers side disc[:(!], how on earth do these things come out.....ever get that felling that your making it tighter?[:(!]
Xantia Front Disc + Pad Change
- PicassoPigeon
Disk retaining screws=best to drill them out.Use a drill bit about the size of the screw head,& drill the heads off them.Thats what i have done in the past.Quick & easy.You can usally then use a pair of mole grips to undo the rest of the screw when the disk is off.Or not bother.The screws dont do a lot,not once the caliper is on .Mine have no retaining screws because of the same problem.
Try using a long breaker bar to undo the caliper nuts.Mine were very tight when i first changed the disks.Used a breaker bar & a bit of brute force & the came undone.
Try an impact driver,the harder you hit then the better the result[^]
As you hold the driver twist it in the direction you are going.
This tool has saved the day on several occasions[8D]
________
GIFT CARDS
________
GIFT CARDS
- PicassoPigeon
[:D][:D]WooHoo!![:D][:D] All done and back on the road thanks to everybody on here and my <font color="green">Off to Norway</font id="green"> topic. Had to Drill the disc screws out but the caliper support bolts came away in the end, I guess my Rex arms(Toy Story) are just not up to it.
MOT tomorrow i think, before we leave for our drive to Norway on the 12th Aug.
Once again thank you to all of you!!![:D]
