Typical problem, same on most exclusive alloys as well... go to your nearest Stealer who should be able to direct you to a suitable tre fitter. Their is a technical reason for balance weights being on the outside or the outside or both... again, a decent tyre fitter can advise.
Ian
Wheels - Tyne & Wear
PowerLee
Hi
I had similar problems with the 405 I had that was fitted with the 306 15" Cyclone alloy wheels, No centres on these either.
Most tyre fitting places should have the adapter for there balancing machine to do these wheels, But it depends if they can be bothered to spend the 5 minutes setting it up.
rory_perrett
pete_wood_uk
