Anyone any ideas for help on this one ?
OI have a 95 1.9td Xantia SX. In the last week or so, it has started "knocking" from under the front end when being driven, particularly on semi-bumpy roads.
It APPEARS to be "lower down" than the engine, but I'm just wondering if there's anything these beasts are renowned for breaking that I can look out for specifically, rather than just grope around blind ?
Any help looked forward to !!!!
Regards,
Lee.
Xantia - Knock knock !!
johnlyn
FatController
- x 1238
johnlyn
mezuk04
FatController
OK - I'm no mechanic here so lets see.
The cars up on ramps, behind the sump is a bar running side to side, from one wheelwell to the other. There is a "ball-joint" at the end of this, attached to a bar which goes up toward the bonnet and seems to be bolted at the other end, either to the firewall (?) or to the wheel assembly - in any case it's about 12-16 inches long - roughly.
Are we saying that I need to replace this short bar - in full ?
If so - is Citroen the best place to go for it - and how much is it likely to cost ? Also - should I replace both sides at the same time ?
Regards,
Lee.
Regards,
Lee.
AndersDK
Lee - this forum is hosted by GSF.
That's why you buy parts at GSF [;)]
https://secure.gsfcarparts.com/shop/
select Citroen -wait- select Xantia -wait- select suspension and wheels - make your choise [8)]
FatController
sponix
johnlyn
FatController
OK - I've identified what I need, spoken to mein Host and got it all priced up - even got one of the mechanics at work do agree to do the job as a foreigner !!!!
Question is - while he's doing the drop-links, would it be recommended to get him to change the bushes toward the MIDDLE of the anti-roll bar seeing he's down there anyway ????
Are they easy to change, or are they like an S40 Vulvo and hidden away above some subframe member ?
Lee.
Lee.
jeremy
