Draper fault code finder
oscarloco
Has anyone bought a Draper fault code reader for a ZX? Are they good? Comments please.
lighteninguk
yes,
although the electronics are very basic and can be replicated yourself with a switch and an led with resistor, it does save much hassel to buy this unit.
my fault code reader helped me through curing my unsteady idling,
not realy much to say about them tho, easy to connect (just make sure you get a good earth, which seems closer to the batter the better i found, so i used the batter securing bracket a gooden), good instruction manual tho, has a list of codes and some rough ideas on how to cure an error code which isnt bad.
Edd
Edd
oscarloco
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by lighteninguk</i>
yes,
<font color="red"><b>although the electronics are very basic and can be replicated yourself with a switch and an led with resistor, it does save much hassel to buy this unit</b>.</font id="red">
Edd
Do you have the electrical diagram to replicate this?
yes,
Edd
lighteninguk
http://www.tramontana.co.hu/citroen/fuel/test.html
^that website has a small diagram and text about it at the bottom of the page. yes the page is geared towards BX's, but the code reading part of it is the same for ZX's
Paulmi16
- x 3
lighteninguk
czenda
Are the fault codes set by some standard for all injection makes and types, or are they system/car/year-specific?
What I mean is - if e.g. 36 = oxygen sensor heating on 92 1,6 BX with Magnetti-Marelli G system, will it be the same 36 = oxygen sensor heating on 93 1,1 Fiat Uno with Bosch Mono Jetronic [?]
aengus
