my shed wont start
petherwin
my shed wont start
Unread post by petherwin »
bit of a rare breed but a good workhorse.my diesel savana has a problem,I've lost power to heater plugs and fuel pump solinoid,if I run a wire direct from the battery to the above it fires up.please help!
martyhopkirk
Unread post by martyhopkirk »
Sounds like a fuse (god only knows where not having the relevant BOL to hand) or wire. Check if the supply for this runs via a relay - if so this may be duff. Simple trace and check im afraid - pain in the bum, but you should be able to do this in an evening.
waynedl99
Unread post by waynedl99 »
more likely the relay I'd think, don't runt he power from the battery too often though.
Renault Safrane 3.0i V6
Citroen Xantia 2.0i Turbo VSX Estate
Citroen Xantia Activa
MOTORBIKES :)
