turbocharger xantia estate 1.9td update
tazman3
hi there i am having major snags keeping my 96 xantia estate above 40 mph going up hills. i can hit a major hill at 70 mph in fifth but by the time im half way up im in third at nearly 40mph. my mate reckons possible no boost from turbo and has suggested i get a boost gauge to check if turbo engaging. he also mentioned wastages or something like that anyway. he explained how the turbo worked and i could see that but does anyone know if the turbo is a common problem with the 1.9td engine?? or does anyone have any other ideas. much appreciated cheers[:(]
jeremy
Its probably much simpler and no where near as interesting. The boos pressure is communicated to an extra fuel device on the pump by a thin rubber pipe running between the high pressure inlet system (ie after the turbo) and the injection pump and this pipe has probbaly split or fallen off.
On my TD BX the intercooler is on top of the engine and the pipe comes off a point in the centre of the intercooler and runs across the front of the engine to the pump. Its different on your Xantia but the pipe should be quite easy to find.
Check all the pipe and its branches - as on some it also feeds an averboost warning light switch and a loss of pressure anywhere will affect the operation of the extra fuel device.
Jeremy
Jeremy
- x 1238
mbunting
tazman3
tazman3
jeremy
You are not looking at the turbo - but for a pipe leading from the induction system to the injection pump.
Turbo's are generally reliable and if they fail the usual failure is of the seals which allows oil to leak into the exhaust and gives a characteristic could of blue smoke. It is possible the wastegate has stuck but again this is unusual.
Find this pipe and check it carefully - its easy and cheap to deal with.
Jeremy
Jeremy
tazman3
Kowalski
There should be a small rubber hose going from the top pipe from the intercooler (the one that goes into the inlet manifold) to a mushtoom shaped device on top of the fuel pump. That is the enrichment device that lets the fuel pump put more fuel into the engine when there is turbo boost available, if it isn't there your turbo will behave as a non-turbo.
The enrichment device contains a diaphragm that can split or puncture and that would stop it working too.
jeremy
tazman3
cheers guys i found the prob. the big plastic pipe that goes over the back of the engine to the turbo wasnt attached properly to the intercooler. i only noticed this as i pushed it on and after driving the car for a couple of mins i heard this big whoosh of air. i stop looked under the bonnet to find this pipe off of the intercooler. so i tightened it up and hey presto car is fine. thanks for all your advice jeremy and kowalski[:D]
[email protected]
hi guys
thats very interesting ill have to have a look at my i.9 td xantia it seems to be underpowered espectialy first thing in the morning and seems slow on the whole compared to my last 1.9td xant im thinking after reading this thread i might have the same problem so where exactly is this pipe does it run from the top of the diesel pump.
pete.......................
tazman3
the pipe that i had loose was the big thick air pipe that goes over the top of the engine and connects to either side of the intercooler in front of the radiator.; the other pipe which was ok on mine is as jeremy states comes of the injection pump hope this helps. i have just drove back from portsmouth (180 miles) and i could acually get up hills without having to change down.....[:D][:D]
[email protected]
Kowalski
