about to change the cam belt on my 1.9td 98 xsara
thought about buying a sealey flywheel locking tool to make it
easier,has any one used one of these?,and does any one know
which of the two tools listed for the xsara
would fit, the single tooth or multi tooth models?
i intend to use this tool so it would be easy to remove the
crankshaft pulley bolt,
Kowalski
To lock the flywheel effectively and cheaply, you can get a tool that is basically a piece of bent rod. You insert this into a hole behind the starter motor, through a hole in the flywheel. To lock the fuel pump and camshaft, a couple or three bolts (8mm ?) are required, no special (expensive) tools.
