Hi All
As above, the Mrs drove my 406 with air con switched on. After arriving home, and getting back in to go out again, the air con does not switch on, nor does the internal fan.
I've checked the fuse in the internal fusebox as well as the fuses in the engine compartment, and all are still intact. Tonight, I've totally dismantled the heater control panel to check the sliding 'rheostat' switch which has proven to be ok!
I think I've run out of other things to check! Can anyone please tell me if there is a known problem or if there is any other component to check before I have to take it to the PUG dealer!!
Thanks in advance
Les
1998 S Reg 1.9LSTD Estate
PS Sorry, but just noticed the previous post is asking the same question, but am still after the same answer!!
406 Internal fan stopped working - Now Sorted!!
