Wheels?????
CITROEN-SUCKER
Wheels?????
Unread post by CITROEN-SUCKER »
Hi can anyone tell me will the wheels from a Xantia fit a XM or a C5 or vice versa I know the tires wont be the same size but will the Hubs Fit?????
J.J.
Richard Gallagher
Unread post by Richard Gallagher »
Not sure about the C5 but Xantia's have 4 bolt hub's whereas XM's have 5.
martyhopkirk
Unread post by martyhopkirk »
http://www.kompressor.no/felger/boltesirkel.htm
Try this site for a compatability test.
CITROEN Xantia 93- PCD=4-108 18: HUB Ctr=65,1 Bolt=B12x1,25
CITROEN XM 89- PCD=5-108 45: HUB ctr=65,1 Bolt=B12x1,25
Hub Centre is the same though as Richard says a 5 bolt hub rather than 4, PCD is different, bolt Ctr also the same. May cayse some fouling problems especialy on full lock. Cant comment on the C5. Pug 605 wheels should fit an XM, but again check the offset.
<font size="1">
Edited due to fat fingers!</font id="size1">
bbrucez
Unread post by bbrucez »
C5 has 4 bolts 108 PCD same as all 4 stud Cits & Pugs. Offset varies so you need to measure existing & new wheels and get spacers if necessary.
