Is there a way of doing this? Reason I ask is I know at least one of em's knocking, and I've just bought the last one unipart had in when getting my anti sink sphere. I'd like to know which one is the worst or the only bad one. If they're both bad, then so be it, but I'll have to wait for em to get another drop link in for the other side.
Can you just wiggle em or something to check for play?
Cheers,
Chris.
Testing drop links
they are not easy to test but some fail by running dry of lubricant and injecting some grease 9easier said than done I know) may quieten it - do them one at a time and it may show up.
The correct way is to jack the car carefully to take the load off the anti-roll bar. Again not easy - then attack it with levers and see if you can find play. Not quite so difficult on a 4 post lift as you can lever from the wheel channels but I don't suppose you have one.
They are not expensive so easiest to replace both. I'm sure GSF have them in stock as have others. I wasn't even sure if Unipart were still in business which suggests they have contracted considerably.
Jeremy
Jeremy
Ha, well i did mine to find it was the lower mount not the drop link!
Things to remember when doing them, well to be honest you'll have a near impossible time to get the upper most nut off all the way! you can get it almost to the top without too much hassle, but you have to hold the top of them with a spanner/grips to stop it turning and when the nut gets too hi its difficult to shift! Solutions are either to super heat the nut and trash the nylock, or cut it off with a grinder when you have the nut as high as possible! Obviously my preference is the grinder one but i think there is another possible way to do it!
However you do it, it wont take long, maybe 30 minutes perside max?
Righto, just replaced the drivers side drop link as that was the noisy one AFAIK. The nut size is 17mm and they came off without too much hassle, although an allen key is required to stop the bolt from turning in the middle. Then, I realised that the strut would have to be jacked up as with it dangling whilst the car was jacked up, it was pulling the upper bolt of the drop link at a funny angle and so wouldn't come out. The new one bolted on ok and away we went.
Scrubbing the whole nut/ etc beforehand really helped, as did drowning the whole lot in WD40. No nyloc trouble for me!
