changing steering wheels
sammycitroenzx
Unread post by sammycitroenzx »
hi i have just purchased a citroen xm 2.o ltr vsx estate the only problems i have so far are these
coolent warning light comes on itermitanly although the coolent level is ok as is tempreture
also the steering wheel is worn the rest of the car is spot on can i change the steering wheel its the air bag type with stereo controls for one i have on my spare citroen zx that is sat on my yard it the 1.9 volcane model
thanks
JohnT
Unread post by JohnT »
To change the wheel use a torx driver and remove the two screws to the rear of the wheel. Take care as these are the only screws holding on the air bag. Be sure to re attach the tiny air bag electrical connector to the contact on the wheel. The rest is obvious and is simple. I have done a few of these as the wheel surface breaks up and looks untidy in a nice car.
406 V6
Unread post by 406 V6 »
Shouldn't the battery be disconnected for 15 minutes so that the airbag electrical system discharges to avoid a probable airbag burst?
x 1044
Unread post by wheeler »
you only need to wait 2 minutes (or 10 minutes if the warning light is on or flashing)
