Xantia, no brakes after standing short time.
JohnT
I have replaced all the spheres recently, have bled the system. Now I find that if stopped for 5 minutes I press the brake pedal, engine not running, there are no brakes! I gave myself a fright when allowing the car to move forward on a slope without starting engine. Good handbrake though! Also the car still lowers slightly after starting engine after ten seconds. Any ideas please?
Kowalski
JohnT
JamesQB
- x 5
jeremy
JohnT
Jeremy, no I did not, only opened it half a turn and let it run on max height for couple of minutes then closed it. Anders suggested I do the Citrobics. When I drop it down and then try to raise it to max height, the front end comes up but the rear does not. The pump does not click very often. I then set the lever in the normal position, engine running, and it will rise and then I set to highest position and it will then rise all the way. I can not make it go up and down on one movement. I have checked the height correctors and they seem to be OK. Strange isn't it?
jeremy
jeremy
Doesn't some of this post sound familiar?
http://www.andyspares.com/discussionfor ... C_ID=15019
How old are your anti-sink spheres?
Jeremy
Jeremy
JohnT
jeremy
JohnT
