right, I've sorted the top hose for my rad but now the infamous bottom hose. I'm having trouble fitting the O ring. Should it sit inside the edge of the rad or act like a buffer on the outside edge of the connector??
I suspect it the former & that my O ring is slightly to big, so does anyone know a price for these things if I go to the main dealer?
Cheers
R [:o)]
Common O ring question
- x 94
i always put the O ring onto the hose lube it with somthing slipery like LHM or silicone grease,then as you enter the hole make sure you lokate hose end slot with lug inside neck of rad push in as far as it will go,then i use a long pry bar one side then the other of the back of the ledge on locking device,gentlty but firmly to engage hose fully then rotate locking rig fully into place regards malcolm
James.UK
Hi Ross, best bet is to take the pipe off and fit it to the rad before you put the rad back, that way its easy to see how it works, and what needs doing, the "O" ring is a very tight fit and goes inside the pipe against the shoulder formed when the inside diam is reduced, in situ it should be trapped between the two shoulders thus sealing the joint.
Smother the plastic locking collar in grease and make sure the moving part rotates easily, then line up the slot and the internal lug, and shove it home.. I needed a "Stewart" (oilyspanner) to get mine back into its hole!! [:I] [:D] it's a very very tight fit! Then rotate the collar to lock it all together.. [^]
You have to thread the pipe back down its hole as you put the rad back into position, but its not too bad, a few swear words should do it. [:D]
My pet mechanic tells me the problem with doing them in the car is that they often pop the clip off again after a few days because although it looks and feels right, it wasn't quite located correctly... [:0] [}:)] [:(!]
rossnunn
James.UK
My new one was bigger in actual size of rubber used to make the "O" ring, but was the same size as the old one otherwise, however, I could not get the new one in at all!! so I used the slightly thinner old one, but even then it needed Stewarts (oilyspanner) muscle power to get the pipe back into its hole!!
- x 94
rossnunn
- x 94
rossnunn
rossnunn
rossnunn
