got the warning lights up today....low lhm and STOP!!
when topping up on high suspension setting with engine running, i noticed a BIG outpouring of lhm from under the reservoir....it was coming from a round end cap on a metal unit [1" diameter approx] points to 10 o'clock from above ..there was a green seal showing...the nut had been screwed in and trapped the seal, cutting it....the resultant fluid loss was massive.
had no tools , so the AA bloke got the call.....he put plastic metal type gunge in the groove where the seal should sit ,and around the head of the nut......d'ya reckon this will be ok long term?? will it contam the lhm??
any ideas welcome norm
ps whats good for cleaning up lhm off the steering rack etc[yeukk]
LHM FLUID..big.leak at end cap under reservoir
poppy
Stempy
jeremy
JohnD
- x 72
- x 94
it is anti/sink valve the screw cap works its way loos then presure damages the seal,i had a job getting new seal from cit,they try to sell you hole unit,if i remember one of the O RING seals you can buy for the pump pipe joints dose the job,i did stop one leaking by removeing the seal peal off the tiny peice of rubber that was sticking out and put it back together and do screw cap up very tight regards malcolm
poppy
checked the AA repair next day....it still seeps a bit. the grey plastic metal has hardened but doesnt seal fully....my worry now is if i can undo the bugger!!......i did 5 or 6 up and downs [citronics !!] to settle it all....it takes 30 secs to go down and 2 mins to go up fully at tickover .......
another ???? do 1999 1.8i 16v sx's have a belt cover at the left of the engine?? my grooved belt is in fresh air.....not good if a stone gets into it??
atb norm
atb norm
- x 94
