406 Rear Track Control Arm Replacement
joyful
Unread post by joyful »
I am getting bad wear on outside of near side rear tyre. The wheel is a bit woobly and somebody mentioned that maybe the rear track control arm joint was worn.
Is this likley (car has done 100,000 miles). Is this easy to replace if this is the problem. Should I do both sides, even if the offside is good.
northernsoulie
Unread post by northernsoulie »
Look at this thread...
http://www.andyspares.com/discussionfor ... C_ID=13860
FWIW, I also had the same sort of problem on the rear tyres of my 1999 406 1.8lx (112,000 miles), and sought out a tracking specialist who found them both out of alignment. A cheap fix at only £48, but it'll take a few '000 miles to prove if the alignment was causing the wear...
