106 xsi ignition failure
stubbsy
no spark,changed plugs,leads,pick up sensor and got coil pack checked but no joy.any ideas
rotodiesel
madasafish
PowerLee
Hi
106 XSI is going to be a pre facelift car, I dont think these ever had the transponder chip system.
To work out if it is immobiliser, Can you hear the fuel pump running for a few seconds when you turn the ignition on? Stick your ear near the O/S/R wheel & get someone to turn the ignition on.
You should hear the fuelpump run for a few seconds as it primes the system.
