... I tell you about a cheap genuine Citroen spare part [:p]
Yesterday I went to (one of many here) a local aftermarket dealer and purchased a BX rear hub/bearing assembly.
To my disappointment the low price was caused by missing (very important) parts : the inner hub cup & the hub nut dust cover. A new hub nut was however supplied.
It's the inner hub cup rusting away that causes the hub bearings to fail in the first place. It's a mystery why it's not supplied with the new assembly.
The Peug405 & the BX part number was listed on the box label - yep - as found in the BX parts list.
I did not dare go and ask Citroen parts shop for this hub cup [:(]
- so I tried Peugeot (the same part on a 405). Lo & behold : the part was available at the stunning bargain of £1.10 - incl. vat [8D]
Now - it would be fun trying Citroen - as they live just next door [:p] I decided no matter what - I would buy a Citroen part too. If they ripped me - I could always stick them the Peugeot invoice in their nose [}:)]
[8] price : £0.75 - incl. vat [:D][:D][:D]
BTW : Citroen part no is RP 3726.14 (which is the Peugeot part no too).
Would you believe me if ...
- x 1238
bxbodger
oscarloco
jeremy
Anders
Its interesting that Peugeot/Citroen haven't amalgamated their parts system in the way that British Leyland did in the early 70's when they created Unipart - which to be fair worked well and meant that you could go to your Jaguar dealer and buy Mini bits. It began to fall apart when Jaguar was privatised and took the spares in hand - no doubt for good reasons and then BMW pulled out and I think its on its own doing something now.
jeremy
jeremy
bikeboyz
AndersDK
Ah -
But if you read carefully what I wrote on the part no - then they are in fact "amalgamated" [:)]
We all know that the old Cit part no's 95.xxx.xxx in many cases are obsolete - but the parts still exists - on a RPxxxx.xx no. This is in fact the Peugeot part no - according to the online system I looked on at the peug spare part dpt. The peugeot parts only have this type/code of part no's.
vanny
Old 95 part numbers have mortly been replaced with 96 numbers! The RP means nothing as the 96 numbers are correctly RP 96 XXX! The cross over only works when it is the short number usually in the 4x2 format 'xxxx.xx' as these are cross over numbers. I often use the local Pug parts department as it is in walking distance (Citroen being a good 5+miles either direction), and fortunatley the franchise also owns a Citroen parts desk. On numerous occasions i have gone to pug with the Cit reference and for ALL 95 or 96 part numbers there is no Pug equivalent as pug where using a different system again when the numbers where issued, though in nearly all circumstances we can use the Peugeot Laser system to figure out which part it should be
PR-NET is a webbased front end of the LASER Parts Ordering system. Both Peugeot AND Citroen opperate the LASER Parts system and i believe sinc ethey moved the parts centre that the systems have actually been amalgamated. The reason PR-NET exists for Citroen and not for Pug is i believe down to Citroen's history and the ethos of Andre Citroen. His belief was that if you did everything possible for a customers pleasure in a car then they would be back to buy more, part of this was that Citroen where the first company in the world to have a 'parts' desk to supply original parts to customers and non affiliated garages. It's certainly not a new thing for Citroen and i guess it's just one ideal that has lived on!
