hi folks
the light on my air con switch has faded and is difficult to see the difference when its on or off, so i need to put a new bulb in,
ive had o look in haynes and it states i need to remove the steering wheel which i dont want to do. is there any other way i can get to the bulb?
regards
air con light bulb
Stempy
kid
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Stempy</i>
Can you not just pop the switch out. They come to bits quite easily for bulb replacement.
how do you do this stempy, is it simply just with a screwdriver type of thing job? i dont want to damage the switch! is the bulb able to be replaced by 'popping ' out the switch?
Stempy
The switches on mine will pop out with a bit of gentle persuasion from a wide bladed screw driver. Use a piece of card to help prevent damage at the leverage points. The front bit of the switch will come away from the switch body and the bulb holder is inside. I think some people fit LEDs for a clearer indication, you may get something to fit here http://www.ultraleds.co.uk/
Philjw
kid
Looks like ive made a bodge job of it. Ive got the light working fine and it shows through clearly, however now the air con is not working at all, i.e. there is no 'click' and the fans are still. The fans still work when the thermostat is open as normal.
So the light switch comes on, but no click and the fans don’t operate either.
I should add, initially when I took the switch out and put it back in it worked fine, but as soon as I pushed the switch all the way back into its slot it stopped working.
ive had a look at the back at the white connector, there are four wires going into it which all semm ok.
Any ideas please
Any ideas please
kid
Stempy
