Xantia behaving wierd after new spheres
JohnT
Unread post by JohnT »
Xantia 1.9TD 1995. Changed the anti sink, two rear spheres and accumulator. Front spheres are recent and OK. When I start in a morning nothing happens for about ten seconds, then the rear starts to drop and the front appears to rise a little, but it then recovers quickly and rises to normal height. Leaving it for a few hours again nothing happens for 10 sec then the front and rear rises (only a little) to normal height. In fact it is acting similar before I did this work. I have bled it twice.
Any help on this please?
AndersDK
Unread post by AndersDK »
I wonder how you "bled" it ?
You should do the Citaerobics.
JohnT
Thanks for that. It went up, then down but the back now stays down and it is not rising at all now, but the front is working normally. Height corrector do you think? It was driving OK today at the normal height.
AndersDK
Either the plastic link or the HC.
