CLARION PU1562 RADIO NEEDS CD'S !!
poppy
have this set in my xantia....but no changer.....anyone got one or ideas to fit another compatible one ta norm
THELABMAN
Hi Poppy,
I was looking recently for a CD changer and found the following web sites I hope they are of some help to you.
http://www.addacdchanger.co.uk/CD_Produ ... Clarion%29
http://www.caraudioplus.co.uk/pp/Change ... DC628.html
http://www.incardiscount.co.uk/products.asp?cat=7454
To be honest though in the end I gave up and bought a Kenwood MP3/WMA cd player out of Argos for under £67.
Homer
- x 16
poppy
PowerLee
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Homer</i>
Does it have the round DIN plug connector for the autochanger interface?
If so I have a changer I keep meaning to advertize. I think it's a DC628, I'd want less than £67 for it.
<b>[edit]</b> It's a CDC634 or a CDC635, the connector is known as C-BUS
C-BUS is Clarion terminology for the system used on the older CD changers & head units, The connector will be the round standard DIN type on a CDC635 / 635.
This is the same DIN lead that Phillips & Kenwood use on some of there CD changers, BUT they are wired differently.
C-NET is the latest system Clarion uses, C-NET is backwards compatible with C-BUS.
With C-NET you can plug much more stuff on to the head unit, You could in theory have 2 or more cd changers, You just need the little Clarion switching box to wire it up & make it work.
