Towbar fitting
shiney
Towbar fitting
Unread post by shiney »
Mrs shiney has a picasso I want to put a tow bar on it. Is this an easy diy job and are there any instructions on the web?
johnlyn
Unread post by johnlyn »
http://www.witter-towbars.co.uk/Fitting ... s/C27A.pdf
Try this link for the witter towbar, how i did it for my Xantia.
John
martyhopkirk
Unread post by martyhopkirk »
If you buy a decent towbar then yep its an easy enough job to fit - the electrics can pose a problem if its CAN bus / multiplex wiring.
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
Fitting the towbar should be no problem, but Picci's are multiplexed so wiring the 12N socket is a bit complicated. Look at Towsure's website - they do electrical kits with the necessary relays.
gwoolie
Unread post by gwoolie »
Ive been told the multiplex only works from the front and the lighting socket can run direct from the rear lights. This is from an Authorised witter fitter.
jeremy
Unread post by jeremy »
"Authorised witter fitter " - just try saying that after a few beers!
Jeremy
Flynn
Unread post by Flynn »
Towsure used to be very cheap though closer Witter prices now. http://www.towsure.com/. The one I used years ago was fine except though when I asked they assured me it used the pre-drilled holes on the Cit - it didn't. It used two of the four and the other two needed drilling which added a smidgeon of hassle.
