Xantia Heater switch????
dirtydog
Unread post by dirtydog »
My heater fan motor works fine but when i use the 4 or is it 3 speed fan switch I get the full speed and the next one down but when I go to single speed or off the heater fan keeps going it will turn off with the ignition switch. I have had to resort to wiring a switch into a blown fuse which I use inplace of the heater fuse in the fuse box but the wire from the fuse to the switch gets hot. could the fault be in the heater blower resistor.
All help much appreciated.
Regards
DD
