citroen ax immobiliser
steveportia
hi we bought a 2nd hand ax and it seems that the immobiliser has kicked in.What can we do? help us please[:I]
jeremy
steveportia
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by jeremy</i>
Diesel or petrol? Factory fitted or aftermarket? Has it got a keypad?
Jeremy
petrol,we think factory fitted,no keypad
Jeremy
jeremy
I think its right to say that generally they are rather crude and simply interfere with one or two circuits - so with a wiring diagram it won't be that difficult to bypass it. However having said that I know nothing about this one and will confuse you if I say more.
There may be specialist sites on the net that can help. I had to deal with a Range Rover recently and found out all sorts of things about its security system - and could probably have beaten that quite easily as the alarm etc was in a plug in module and presumably I could have sawn it up, found that only a few of the many pins were used and soldered up the plug so it worked all the time. (The problem on this vehicle was a slow discharge of the battery which wasn't helped by the alarm monitoring current)
Jeremy
Jeremy
gardenpeas
- x 1044
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by steveportia</i>
don't think the AX ever came with a factory imobiliser,how are you supposed to disarm this imobiliser ? with a touch key or similar ?
